Ir para o conteúdo principal
Samsung Galaxy Alpha microSIM Card Replacement
  1. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: passo 1, imagem 2 %32 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: passo 1, imagem 3 %32
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha microSIM Card Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy Alpha microSIM Card Replacement, Battery: passo 2, imagem 2 %32
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
  3. Samsung Galaxy Alpha microSIM Card Replacement, microSIM Card: passo 3, imagem 1 %32
    • Remove your Micro SIM card from the slot shown.
Conclusão
11 outras pessoas executaram este guia.
Tyler
Membro desde: 01/22/15
769 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 20-17, Maness Winter 2015 Membro de Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 2,310
