Introdução
The Samsung Galaxy Alpha has a micro USB port that can be replaced in the event it is damaged or malfunctioning.
O que você precisa
On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
Locate the slot at the base of the battery and insert your thumb.
Push slightly toward the battery and out, away from the phone to free the battery.
Uma outra pessoa concluiu este guia.
