Ir para o conteúdo principal
Samsung Galaxy Alpha Back Cover Replacement
  1. Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: passo 1, imagem 2 %32 Samsung Galaxy Alpha Back Cover Replacement, Removing the Back Panel: passo 1, imagem 3 %32
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
Conclusão
To replace the cover, realign the cover with the device and gently press down until you hear the connections click.
12 outras pessoas executaram este guia.
Sarah
Membro desde: 01/22/15
916 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-17, Maness Winter 2015 Membro de Cal Poly, Team 20-17, Maness Winter 2015
CPSU-MANESS-W15S20G17
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 3,633
