Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Switch off the phone.
Remove the battery and any installed SIM and memory card.
Remove the 7 Phillips screws.
Use a plastic tool to remove the back cover.
vibrating motor
Disconnect the earpiece & light sensor flex cable.
Take off the Volume Up/Down buttons flex cable.
Do the same with the Power button flex cable.
Lift the microphone.
Lift the board from the right side and disconnect the LCD display flex cable.
Remove the board from the middle frame.
This is the loudspeaker & audio jack connector module.
Use a hair dryer and warm the touch screen glass to make adhesive soften.
Use a plastic tool for separating the glass from the middle frame.
Again by using a plastic tool, separate the LCD display from the middle frame.
Clean the middle frame and install the LCD display.
Install the touch screen and start with reassembling.
23 outras pessoas executaram este guia.
