Ir para o conteúdo principal
Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement, Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera: passo 1, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement, Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera: passo 1, imagem 2 %32
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory card.
  2. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 2, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 2, imagem 2 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 2, imagem 3 %32
    • Remove the 7 Phillips screws.
    • Use a plastic tool to remove the back cover.
    • vibrating motor
  3. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 3, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 3, imagem 2 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 3, imagem 3 %32
    • Disconnect the earpiece & light sensor flex cable.
    • Take off the Volume Up/Down buttons flex cable.
    • Do the same with the Power button flex cable.
    • Be careful don't brake the flex cables.
  4. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 4, imagem 2 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 4, imagem 3 %32
    • Lift the microphone.
    • Lift the board from the right side and disconnect the LCD display flex cable.
    • Remove the board from the middle frame.
  5. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 5, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 5, imagem 2 %32
    • This is the main camera.
  6. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 6, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 6, imagem 2 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 6, imagem 3 %32
    • This is the loudspeaker & audio jack connector module.
  7. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 7, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 7, imagem 2 %32
    • Loudspeaker and light sensor module,
  8. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 8, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 8, imagem 2 %32
    • Disconnect the touch screen flex cable.
  9. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 9, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 9, imagem 2 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 9, imagem 3 %32
    • Use a hair dryer and warm the touch screen glass to make adhesive soften.
    • Use a plastic tool for separating the glass from the middle frame.
  10. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 10, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 10, imagem 2 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 10, imagem 3 %32
    • Again by using a plastic tool, separate the LCD display from the middle frame.
  11. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 11, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 11, imagem 2 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 11, imagem 3 %32
    • Clean the middle frame and install the LCD display.
  12. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 12, imagem 1 %32 Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 12, imagem 2 %32
    • Install the touch screen and start with reassembling.
  13. Samsung Galaxy Ace Touch screen Glass, LCD Display, Earpiece, Loudspeaker, Main Camera Replacement: passo 13, imagem 1 %32
    • That is all.
    • Did you do it successfully?
Conclusão
23 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
192.056 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.525 guias
Um comentário
Amar touch ta lagbe
nj nazmul - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 31
Duração total: 9,380
