Ir para o conteúdo principal
Samsung Galaxy A5 (2017) Back Cover Replacement
O que você precisa
  1. Samsung Galaxy A5 (2017) Back Cover Replacement, Back Cover Removal: passo 1, imagem 1 %32
    • Power off your phone before beginning disassembly.
    • Use an iOpener to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Samsung Galaxy A5 (2017) is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A5 (2017) Back Cover Replacement: passo 2, imagem 1 %32 Samsung Galaxy A5 (2017) Back Cover Replacement: passo 2, imagem 2 %32 Samsung Galaxy A5 (2017) Back Cover Replacement: passo 2, imagem 3 %32
    • Insert an opening pick at the bottom end of your phone.
    • If you can't manage to insert the opening pick between the back cover and the frame, you can use a suction handle to create a small gap.
    • Start to slide the tip of the opening pick to the bottom left corner and cut the adhesive with it.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing. Insert a new opening pick and start to cut the adhesive on the left side of the phone.
  3. Samsung Galaxy A5 (2017) Back Cover Replacement: passo 3, imagem 1 %32 Samsung Galaxy A5 (2017) Back Cover Replacement: passo 3, imagem 2 %32 Samsung Galaxy A5 (2017) Back Cover Replacement: passo 3, imagem 3 %32
    • Use an opening pick to cut the adhesive on all sides of the phone. Leave one opening pick in every corner to prevent the adhesive from resealing.
    • Reuse an iOpener if the adhesive becomes hard to cut. During the removal process the back cover is under tension all the time and is likely to break if the adhesive isn't loose enough.
    • Insert an opening pick on the right side of the phone after you cut the adhesive on all sides. Flip it sideways until you can get a good grip on the back cover.
  4. Samsung Galaxy A5 (2017) Back Cover Replacement: passo 4, imagem 1 %32
    • Remove the back cover from the phone.
    • Before applying new adhesive remove any remaining adhesive from the back cover and the frame and clean the areas with isopropyl alcohol and a lint-free cloth.
Conclusão
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
19 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
203.329 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
4 comentários
genial, tutorial paso a paso pregunta cual es el adhesivo que se utiliza ???
Erik Astudillo - Responder
Hi Erik, you can buy precut and for the A5 optimized back cover adhesive or the precut adhesive card in our shop.
Dominik Schnabelrauch -
Where can you buy the back glass?
The JoMan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 37
Últimos 30 dias: 203
Duração total: 36,442
