Ir para o conteúdo principal
Samsung Galaxy A5 (2016) Display Replacement
O que você precisa
  1. Samsung Galaxy A5 (2016) Display Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement, Back Cover: passo 1, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement, Back Cover: passo 1, imagem 3 %32
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • With a suction handle lift the back cover to insert an opening pick.
  2. Samsung Galaxy A5 (2016) Display Replacement: passo 2, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 2, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 2, imagem 3 %32
    • Slide the pick up to the middle to separate the back cover from the frame.
    • Insert a second opening pick and move around the right corner along the bottom and around the left corner.
  3. Samsung Galaxy A5 (2016) Display Replacement: passo 3, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 3, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 3, imagem 3 %32
    • Take another opening pick and continue towards the top corner.
    • Here you want to use one more pick for the last part at the top.
  4. Samsung Galaxy A5 (2016) Display Replacement: passo 4, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 4, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Insert a plastic card at the bottom and slide it underneath the back cover.
  5. Samsung Galaxy A5 (2016) Display Replacement: passo 5, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 5, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 5, imagem 3 %32
    • Heat up the back cover once again so you can slide the plastic card towards the top.
    • Always take a peek underneath the back cover to not damage any parts like the NFC antenna.
    • Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
    • Be sure to remove any residue from the glue and apply new adhesive when reassembling.
  6. Samsung Galaxy A5 (2016) Display Replacement, Display: passo 6, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement, Display: passo 6, imagem 2 %32
    • Remove the SIM card tray.
    • Remove the 17 Phillips #00 screws on the midframe.
  7. Samsung Galaxy A5 (2016) Display Replacement: passo 7, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 7, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 7, imagem 3 %32
    • Push the exposed part of the battery away from the midframe to separate the components.
    • You may need the IMEI sticker on your old battery to identify your phone in the future, be sure to transfer it to the replacement battery.
  8. Samsung Galaxy A5 (2016) Display Replacement: passo 8, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 8, imagem 2 %32
    • With a flat end of a spudger disconnect the display connector.
    • Reheat the iOpener and use it to loosen the adhesive under the display.
  9. Samsung Galaxy A5 (2016) Display Replacement: passo 9, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 9, imagem 2 %32
    • Use a Jimmy to get between the frame and the front panel.
    • Pry up the display unit just a bit so you can put an opening pick behind the display.
    • You just want to insert the tip of the opening pick where the display cable is.
    • Slide down the side to separate the glue. At the bottom you can insert the opening pick further to keep the adhesive from resealing.
  10. Samsung Galaxy A5 (2016) Display Replacement: passo 10, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 10, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 10, imagem 3 %32
    • Repeat the same procedure on the other side.
    • Here you can insert the opening pick as far as half of an inch to get the glue off behind the battery.
    • Slide down to where the display ends.
  11. Samsung Galaxy A5 (2016) Display Replacement: passo 11, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 11, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 11, imagem 3 %32
    • Now slide along the bottom to get the glue off.
    • Be careful, there are two touch buttons on each side behind the front panel. In the middle only go as deep as where the home button begins.
  12. Samsung Galaxy A5 (2016) Display Replacement: passo 12, imagem 1 %32
    • Re-heat the display unit for the next few steps.
  13. Samsung Galaxy A5 (2016) Display Replacement: passo 13, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 13, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 13, imagem 3 %32
    Plastic Cards
    $2.99
    Comprar
    • On the left hand side (where the motherboard sits) replace the opening pick with a plastic card to get to the glue behind the battery.
    • Continue separating the adhesive until you reach the display cable.
  14. Samsung Galaxy A5 (2016) Display Replacement: passo 14, imagem 1 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 14, imagem 2 %32 Samsung Galaxy A5 (2016) Display Replacement: passo 14, imagem 3 %32
    • Separate the display from the display frame and cut the remaining glue at the top with an opening pick.
    • Carefully slide the display cable out of the slot in the display frame.
  15. Samsung Galaxy A5 (2016) Display Replacement: passo 15, imagem 1 %32
    • Before you start reassembling plug the new display to the motherboard and perform a short test by powering on your phone. See if the display lights up and the touch works properly.
    • Remove any adhesive from the display and rear glass and reapply as necessary.
Conclusão
63 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
117.504 Reputação
Autoria de 188 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
8 comentários
dear sir,
i follow the steps above but still my mobile with black screen and colored dots, what shall i do please help me
mohammad khateeb - Responder
Dear sir
Mera Mobile gir jane ke karan screen tut gya h but work kar rha mai chahta hu ise repair karwana please contact me Mobile -7903248447
PAWAN KUMAR - Responder
Miei parole ci sono sei molto bravo , grazie mille per tutorial , e ti mandò un mondo di salute e più grande fortuna dell' mondo Grazie…..
Teofil Timis - Responder
Evo da i ja ostavim komentar. kad vec svako na svoj jezik pise
sturman - Responder
Unfortunately, Croatian is not yet available on our site. A team of volunteers has already started localizing the iFixit user interface into Croatian, but there is still lots of work to do. We are using an open web translation software which is called "Crowdin". If you'd like to participate, you can just follow this link and create an account to start translating: https://crowdin.com/project/ifixit/hr# , but I would recommend that you read the iFixit translator guidelines first: Translator Guidelines Crowdin. If you’d like to get a notification as soon as we get started with Guide and Wiki translations in Croatian, you can just fill in this form:++ https://docs.google.com/forms/d/e/1FAIpQ.... I stay at your disposal for any further question or concern!
Sandra Hiller -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 101
Duração total: 63,577
