Introdução
If your Galaxy A5 won't hold a charge you can use this guide to replace the worn-out battery.
If your battery is swollen, take appropriate precautions.
This guide involves removing the rear glass cover and the mid frame. You will need replacement adhesive to reattach the back cover to the phone.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
O que você precisa
Take an iOpener to heat up and soften the glue behind the back cover.
With a suction handle lift the back cover to insert an opening pick.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Insert a plastic card at the bottom and slide it underneath the back cover.
Heat up the back cover once again so you can slide the plastic card towards the top.
Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
Remove the SIM card tray.
Remove the 17 Phillips #00 (3.4 mm) screws on the midframe.
Again carefully pry up the battery and insert the tip of an opening pick on the left side.
Now you can use a second opening pick and slide it in on the right side. Also don't insert too far to avoid damaging the LCD screen underneath.
Slide with the opening picks towards the top to free the battery of the adhesive.
Now you can remove the battery.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
54 outras pessoas executaram este guia.
19 comentários
Guten Tag,
Ich habe meinem Battery ausgetauscht, nach dem Austausch das Volume Taste und sim slat 2 funktioniert nicht mehr.
wie kann ich die reparieren?
vielen dank
Prüfe, ob die Kontakte der Lautstärkeknöpfe und das Flachbandkabel noch in Ordnung sind (nicht verschmutzt oder verbogen). Das mit dem Sim Slot klingt schon etwas seltsam. Das Modell in dieser Anleitung hat nur einen Sim Slot und einen micro-SD Slot.
Hi in step 7 you can see a black thin plastic over the battery. Is it the NFC antenna?
Yes, this is the NFC antenna.
Just saved 2k INR by following this guide !!! Thanks Man
Can i get some screws of this mobile i mean like this mobile ,actually i have also a a5 but i have no mobile screws then i want
The glue is too strong, it's exaggerated! You will easily kill the display.
The glue is too strong, it's exaggerated! You will easily kill the display!
عندي ضعف في شبكة الاتصال ايش السبب
اذا تركت بعض الغراء علي الهوائي هل يسبب له
Whats the screw size
The screws are 3.4 mm long (information added in the step). Unfortunately not sure where to get them.
Danke für die Anleitung, hat super funktioniert. Ich habe meine Bemühungen auf Video festgehalten: https://youtu.be/yfY4Jk4IhO0
Gratulation zur gelungenen Reparatur und Danke für den Link zum Video.
