Introdução
Use this guide to replace a broken display or cracked glass of your Samsung Galaxy A3.
O que você precisa
Switch off your phone.
Use an iOpener to soften the glue on the edge of the display. Concentrate on the sides first and then on the bottom part.
With an iSclack or a suction handle you can lift the display a little bit to get in the gap with an opening pick.
When the glue ist loosened enough on the side you can lift the display a little bit more to get underneath the display with an opening pick.
Take a second opening pick and work your way just around the bottom edge.
Repeat the last step and this one on the other side.
Grab the iOpener once again to heat up the bottom and top part to further soften the glue.
Now you will be able to move the picks at the bottom closer to the home button and eventually open the display towards the top.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
43 outras pessoas executaram este guia.
1Comentário do guia
Hi, thank you for this guide. I want to replace my battery, but I don’t see how to re-seal the screen in the end? Do we need to heat the screen the same way we did? Or do we need to use new adhesive?
