Ir para o conteúdo principal
Samsung Galaxy A3 2015 Glass / Touch Replacement
O que você precisa
    • To complete the repair follow instructions from the tutorial. If you need any further info feel free to comment below the video.
Conclusão
17 outras pessoas executaram este guia.
Alex Sander
Membro desde: 02/28/17
38.237 Reputação
Autoria de 202 guias
5 comentários
I have a Galaxy A3 model. it fell in water while using it. It switched off then after some minutes it restarted but the screen started misbehaving like opening multiple apps on the phone. the following day the touch screen couldn’t respond but it was on showing my lockscreen but it wasn’t responding. I took it to repair and the guy told me the only option was replacing the whole screen… I dont know if thats the only option or if the glass is replaced could solve the problem.
MosesMaundu - Responder
The technician i s probably right, you need to replace the whole display.
Alex Sander -
After separating the glass and the LCD there was lots of glue on the LCD. How did you remove it that it became so neat n clean???
Siamak - Responder
Hi Siamak, you may try and get rid of the remaining adhesive with isopropyl alcohol (>97%)
Tobias Isakeit -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 32
Duração total: 4,145
