Ir para o conteúdo principal
Samsung Galaxy A10 Charging Port Replacement
Vídeo de Apresentação
  1. Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: passo 1, imagem 1 %32 Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: passo 1, imagem 2 %32 Samsung Galaxy A10 Charging Port Replacement, Remove the back cover: passo 1, imagem 3 %32
    • Remove the SIM Tray.
    • Use plastic tools to separate the back cover.
  2. Samsung Galaxy A10 Charging Port Replacement: passo 2, imagem 1 %32 Samsung Galaxy A10 Charging Port Replacement: passo 2, imagem 2 %32 Samsung Galaxy A10 Charging Port Replacement: passo 2, imagem 3 %32
    • Remove the silver Phillips screws to be able to disassemble the motherboard shields.
  3. Samsung Galaxy A10 Charging Port Replacement: passo 3, imagem 1 %32 Samsung Galaxy A10 Charging Port Replacement: passo 3, imagem 2 %32 Samsung Galaxy A10 Charging Port Replacement: passo 3, imagem 3 %32
    • Disconnect the battery.
    • Remove the screws and the charging board shield.
  4. Samsung Galaxy A10 Charging Port Replacement, Remove the charging board: passo 4, imagem 1 %32 Samsung Galaxy A10 Charging Port Replacement, Remove the charging board: passo 4, imagem 2 %32
    • Disconnect the Main flex cable and the coaxial antenna cables and remove the charging board.
  5. Samsung Galaxy A10 Charging Port Replacement: passo 5, imagem 1 %32 Samsung Galaxy A10 Charging Port Replacement: passo 5, imagem 2 %32 Samsung Galaxy A10 Charging Port Replacement: passo 5, imagem 3 %32
    • Cover the microphone hole to prevent microphone damage.
    • Use hot air to remove the Micro USB connector.
  6. Samsung Galaxy A10 Charging Port Replacement: passo 6, imagem 1 %32 Samsung Galaxy A10 Charging Port Replacement: passo 6, imagem 2 %32 Samsung Galaxy A10 Charging Port Replacement: passo 6, imagem 3 %32
    • Clean the tin and install the new charging connector.
  7. Samsung Galaxy A10 Charging Port Replacement: passo 7, imagem 1 %32 Samsung Galaxy A10 Charging Port Replacement: passo 7, imagem 2 %32
    • Clean the board and test the device.
Conclusão
11 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.882 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.516 guias
Um comentário
Waste of time unless you're obsessed with soldering. Just buy a complete board. Cheaper, easier and quicker.
[deleted] - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 54
Últimos 30 dias: 273
Duração total: 7,577
