Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Use this guide to replace a worn-out or dead battery in your Galaxy A10.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
  1. Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone. Press firmly to eject the tray.
    • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
    • Press firmly to eject the tray.
  2. Remove the SIM card tray. When reinserting the cards, make sure to properly orient them in the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  3. The back cover is held in place by plastic clips. Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
    • The back cover is held in place by plastic clips.
    • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
  4. Slide the opening pick to the bottom left corner to release the clips. Slide the opening pick to the bottom left corner to release the clips. Slide the opening pick to the bottom left corner to release the clips.
    • Slide the opening pick to the bottom left corner to release the clips.
  5. Slide the opening pick along the left edge to the top left corner of the phone, to release the clips. Slide the opening pick along the left edge to the top left corner of the phone, to release the clips. Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
    • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
  6. Slide the opening pick from the top left corner to the top right corner to release the plastic clips. Slide the opening pick from the top left corner to the top right corner to release the plastic clips. Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
    • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
  7. Slide the opening pick from the top left corner to the bottom right corner to release the remaining clips. Slide the opening pick from the top left corner to the bottom right corner to release the remaining clips. Slide the opening pick from the top left corner to the bottom right corner to release the remaining clips.
    • Slide the opening pick from the top left corner to the bottom right corner to release the remaining clips.
  8. Remove the back cover. Remove the back cover.
    • Remove the back cover.
  9. Remove the three Phillips #00 screws (3 mm length).
    • Remove the three Phillips #00 screws (3 mm length).
  10. Use the flat end of a spudger to pry up the motherboard cover to release the plastic clips which hold the cover in its place. The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, twist the spudger to make the process easier. Remove the motherboard cover.
    • Use the flat end of a spudger to pry up the motherboard cover to release the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, twist the spudger to make the process easier.
    • Remove the motherboard cover.
    • The remaining plastic clips should release during this process or can be unhinged easily by hand.
  11. Use a spudger to disconnect the battery by prying the connector straight up from its socket. Use a spudger to disconnect the battery by prying the connector straight up from its socket.
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  12. Use the flat end of a spudger to pry up and disconnect the interconnect and display flex cables from the motherboard. Use the flat end of a spudger to pry up and disconnect the interconnect and display flex cables from the motherboard. Use the flat end of a spudger to pry up and disconnect the interconnect and display flex cables from the motherboard.
    • Use the flat end of a spudger to pry up and disconnect the interconnect and display flex cables from the motherboard.
  13. Remove the eight Phillips #00 screws from the bottom (3 mm length).
    • Remove the eight Phillips #00 screws from the bottom (3 mm length).
  14. Remove the daughterboard cover.
    • Remove the daughterboard cover.
  15. Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket. Remove the interconnect cable.
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
    • Remove the interconnect cable.
  16. Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes. You might need to repeat this procedure several times during the battery replacement.
    • Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes. You might need to repeat this procedure several times during the battery replacement.
  17. Carefully bend the display cable away from the battery to make room for removal. Take care to bend the cable only slightly. Take care to bend the cable only slightly.
    • Carefully bend the display cable away from the battery to make room for removal.
    • Take care to bend the cable only slightly.
  18. Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools. Insert a plastic card underneath the bottom edge of the battery. Carefully slide it underneath the battery to loosen the adhesive.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert a plastic card underneath the bottom edge of the battery.
    • Carefully slide it underneath the battery to loosen the adhesive.
    • Continue sliding the plastic card underneath to pry up the battery from the bottom.
  19. Remove the battery.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7 outras pessoas concluíram este guia.
Adriana Zwink
Membro desde: 18/12/2019
12.657 Reputação
68 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
134 Membros
15.670 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 74
Últimos 7 dias: 366
Últimos 30 dias: 1,681
Duração total: 14,957
