Introdução
Hello everyone! Today I am going to show you how to replace a battery in the Samsung Keystone 2. It’s very simple if you make sure to follow the directions carefully, so let’s get started!
Ferramentas
Peças
For an easier experience, use an opening tool to remove the back. Simply push the opening tool into the indent in the bottom and work you way around a little so you can pop it off.
Remove the battery by pulling it out, replacing it with a new one, and putting the cover back on.
Quase terminado!
Conclusão
