Ir para o conteúdo principal
Samsung GT-C3750 Battery Replacement
O que você precisa
  1. Samsung GT-C3750 Battery Replacement, Expose the battery: passo 1, imagem 1 %32 Samsung GT-C3750 Battery Replacement, Expose the battery: passo 1, imagem 2 %32 Samsung GT-C3750 Battery Replacement, Expose the battery: passo 1, imagem 3 %32
    • Close the phone and flip it on it's back.
    • Under the SAMSUNG logo there will be a bit of space to open the phone with your fingernail or a tool.
    • Finally, pull the cover slowly and carefully so it doesn't break.
  2. Samsung GT-C3750 Battery Replacement, Replacement: passo 2, imagem 1 %32 Samsung GT-C3750 Battery Replacement, Replacement: passo 2, imagem 2 %32
    • Put your finger on the space highlighted in red, and press while slowly lifting the old battery.
    • Next insert the new battery by following the steps above backwards and making sure the SAMSUNG logo is on the top and the pins of the phone align with the contacts of the battery correctly.
    • Make sure the battery is placed correctly.
  3. Samsung GT-C3750 Battery Replacement, Success!: passo 3, imagem 1 %32 Samsung GT-C3750 Battery Replacement, Success!: passo 3, imagem 2 %32
    • The only thing left to do is to put the cover back and press it slightly.
Conclusão
To reassemble your device, put the cover back.
Uma outra pessoa concluiu este guia.
GK_
Membro desde: 08/20/23
376 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 62
