Ir para o conteúdo principal
Samsung GALAXY Note 3 - Service / Test menu
Vídeo de Apresentação
  1. Samsung GALAXY Note 3 - Service / Test menu, Samsung GALAXY Note 3 - Service / Test menu: passo 1, imagem 1 %32 Samsung GALAXY Note 3 - Service / Test menu, Samsung GALAXY Note 3 - Service / Test menu: passo 1, imagem 2 %32 Samsung GALAXY Note 3 - Service / Test menu, Samsung GALAXY Note 3 - Service / Test menu: passo 1, imagem 3 %32
    • *#06# - IMEI
    • *#1234# - Version
    • *#12580*369# - Main Version
    • *#0228# - Battery Status
    • *#0808# - USB Settings
    • *#0011# - Service Modes
    • *#0*# - Service / Test / Hidden functions
    • *#9900# - System Dump menu
    not working in my verizon Note 3
    HIREN PATEL - Responder
    Same. - also Verizon unit. (w/unlocked BL) none worked.. - Absolutely LOVE V/branded phones. :D
    Thor - Responder
    Ussd code not displaying,in my Samsung Galaxy note 3 olleh.every time when I display it says try again.help me please.
    lameck emmanuely - Responder
    If Samsung Note 3 Wi-fi is not turn on how to fix it?
    Shahg - Responder
Conclusão
93 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.368 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.463 guias
16 comentários
Does this work with all Galaxy Note 3 phones? I have one from US Cellular and can't seem to get this to work.
atomashaska - Responder
Enter this code first *#22745927 to enable / disable hidden menu.
ZFix -
Yes, unless your mobile phone is installed with a system that is not a Samsung Experience.
zhanbohan2008@qq.com -
You're running a custom ROM. Codes can very between ROMs in certain circumstances. Have you tested these on the stock ROM?
Harley Pisa - Responder
I can not make phone calls with my note 3 after I purchased a activation kit for net10. Im not sure of why is it my apn settings or where do I go from here? I have tried every thing
Donnie King - Responder
could u help me i have samsun glaxy note 3 . when i want to dile number it outomaitcally add +1 then i cant call
i cant calll.
how to remove +1 from my all contact .
engineermasoodazizi - Responder
allso, when i want to from google direct take number then otomatically it added +1
how to remove +1 for contact . i have lots number . when i call , all added +1
pleas help me
please help me my phone is invert colour mode how can change normal mode?
jayasinghpv - Responder
I don't know. You can ask Samsung customer service.
Go to setting type on searche
Inverted and deactivate it .
Ayoubblack Hotmal -
It's Samsung Galaxy note3 and only the touch screen doesn't respond for no reason. I dialed *#0*# nd clicked for touch ….but it didn't work (no hardware damage).Help.
Hannah Baker - Responder
Dear I have N900V samsung Note 3, no any code works on it even *#06#
Pls help
GB KHAN OFFICAL - Responder
I have an /sm_n9005
With a custom room lineàge os àndro pie 9 the self test doesnt come out when i dial *#0*# help
Ayoubblack Hotmal - Responder
I can not make phone calls with my Galaxy j7 after I insert sim card for few calls one or three calls after that “ not registred on network “ command appears on the screen . but the sim card works properly on other phone,I have tried every thing. please help me to fix this problem
eshetu_bkl - Responder
I cannot activate MTN bundles with my Samsung Galaxy Note 3 I can check just credit but to process any other code it cannot
ejabi victor - Responder
Sir my phone mic works on calls with open speaker and not record voice on whattsapp
Malik wajdan ali - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 51
Duração total: 85,792
