Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Put your fingernail in the little slot at the top, and just pull back. It doesn't require much force. There is nothing you can break really, so pull!
The rear cover removed, lying next to rest of the phone.
Pick up the battery at the end, and lift away.
If installing the battery, align the arrow with the three silver contacts, and drop it in. Put the rear cover over the back, and give it a gentle push.
