Ir para o conteúdo principal
Samsung Exhibit II 4G Top Rear Housing Cover Replacement
O que você precisa
  1. Samsung Exhibit II 4G Top Rear Housing Cover Replacement, Battery: passo 1, imagem 1 %32
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: passo 2, imagem 1 %32
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Top Rear Housing Cover Replacement, Top Rear Housing Cover: passo 3, imagem 1 %32
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: passo 4, imagem 1 %32
    • Remove the top cover.
  5. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: passo 5, imagem 1 %32 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: passo 5, imagem 2 %32
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Top Rear Housing Cover Replacement: passo 6, imagem 1 %32 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: passo 6, imagem 2 %32 Samsung Exhibit II 4G Top Rear Housing Cover Replacement: passo 6, imagem 3 %32
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
Conclusão
David R
Membro desde: 07/20/15
1.152 Reputação
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 25
Duração total: 291
