Ir para o conteúdo principal
Samsung Exhibit II 4G Rear Facing Camera Replacement
O que você precisa
  1. Samsung Exhibit II 4G Rear Facing Camera Replacement, Battery: passo 1, imagem 1 %32
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
    Pergunte ao FixBot
  2. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 2, imagem 1 %32
    • Insert plastic opening tool under battery.
    • Pry battery out.
    Pergunte ao FixBot
  3. Samsung Exhibit II 4G Rear Facing Camera Replacement, Top Rear Housing Cover: passo 3, imagem 1 %32
    • Pry the top cover upward to remove it from the phone.
    Pergunte ao FixBot
  4. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 4, imagem 1 %32
    • Remove the top cover.
    Pergunte ao FixBot
  5. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 5, imagem 1 %32 Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 5, imagem 2 %32
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
    Pergunte ao FixBot
  6. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 6, imagem 1 %32 Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 6, imagem 2 %32 Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 6, imagem 3 %32
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
    Pergunte ao FixBot
  7. Samsung Exhibit II 4G Rear Facing Camera Replacement, Midframe: passo 7, imagem 1 %32
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
    Pergunte ao FixBot
  8. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 8, imagem 1 %32
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
    Pergunte ao FixBot
  9. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 9, imagem 1 %32
    • With plastic opening tool continue prying around the edge of the back assembly.
    Pergunte ao FixBot
  10. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 10, imagem 1 %32
    • Pull back panel assembly away from main body.
    Pergunte ao FixBot
  11. Samsung Exhibit II 4G Rear Facing Camera Replacement, Rear Facing Camera: passo 11, imagem 1 %32
    • Use the flat end of a spudger to disconnect the camera assembly cable.
    Pergunte ao FixBot
  12. Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 12, imagem 1 %32 Samsung Exhibit II 4G Rear Facing Camera Replacement: passo 12, imagem 2 %32
    • Remove camera from square housing.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 42
Ao todo: 521
