Ir para o conteúdo principal
Samsung Exhibit II 4G Headphone Jack Replacement
O que você precisa
  1. Samsung Exhibit II 4G Headphone Jack Replacement, Battery: passo 1, imagem 1 %32
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Headphone Jack Replacement: passo 2, imagem 1 %32
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Headphone Jack Replacement, Top Rear Housing Cover: passo 3, imagem 1 %32
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Headphone Jack Replacement: passo 4, imagem 1 %32
    • Remove the top cover.
  5. Samsung Exhibit II 4G Headphone Jack Replacement: passo 5, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 5, imagem 2 %32
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Headphone Jack Replacement: passo 6, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 6, imagem 2 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 6, imagem 3 %32
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Headphone Jack Replacement, Midframe: passo 7, imagem 1 %32
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Headphone Jack Replacement: passo 8, imagem 1 %32
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Headphone Jack Replacement: passo 9, imagem 1 %32
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Headphone Jack Replacement: passo 10, imagem 1 %32
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: passo 11, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: passo 11, imagem 2 %32
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
  12. Samsung Exhibit II 4G Headphone Jack Replacement: passo 12, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 12, imagem 2 %32
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
  13. Samsung Exhibit II 4G Headphone Jack Replacement, Rear Facing Camera: passo 13, imagem 1 %32
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  14. Samsung Exhibit II 4G Headphone Jack Replacement: passo 14, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 14, imagem 2 %32
    • Remove camera from square housing.
  15. Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: passo 15, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: passo 15, imagem 2 %32 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: passo 15, imagem 3 %32
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
  16. Samsung Exhibit II 4G Headphone Jack Replacement: passo 16, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 16, imagem 2 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 16, imagem 3 %32
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
  17. Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: passo 17, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: passo 17, imagem 2 %32 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: passo 17, imagem 3 %32
    • Insert flat end of spudger between support panel and front assembly.
    • Using a spudger pry up to create opening to insert plastic opening tool.
  18. Samsung Exhibit II 4G Headphone Jack Replacement: passo 18, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 18, imagem 2 %32
    • Insert a plactic opening tool in opening.
    • Use plastic opening tool to pry around the edge of support panel to free it from front assembly.
  19. Samsung Exhibit II 4G Headphone Jack Replacement: passo 19, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 19, imagem 2 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 19, imagem 3 %32
    • Insert the pointed end of a spudger into gap.
    • Lift spudger away from support plate to remove headphone component.
  20. Samsung Exhibit II 4G Headphone Jack Replacement: passo 20, imagem 1 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 20, imagem 2 %32 Samsung Exhibit II 4G Headphone Jack Replacement: passo 20, imagem 3 %32
    • Use the flat end of the spudger to remove headphone jack component from rectangular housing.
Conclusão
Uma outra pessoa concluiu este guia.
David R
Membro desde: 07/20/15
1.152 Reputação
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 24
Duração total: 333
