Ir para o conteúdo principal
Samsung Eternity Microphone Replacement
O que você precisa
    • Remove the back battery cover.
  1. Samsung Eternity Microphone Replacement: passo 2, imagem 1 %32
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Microphone Replacement: passo 3, imagem 1 %32
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Microphone Replacement: passo 4, imagem 1 %32 Samsung Eternity Microphone Replacement: passo 4, imagem 2 %32
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Microphone Replacement, Motherboard: passo 5, imagem 1 %32
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Microphone Replacement: passo 6, imagem 1 %32 Samsung Eternity Microphone Replacement: passo 6, imagem 2 %32 Samsung Eternity Microphone Replacement: passo 6, imagem 3 %32
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Microphone Replacement: passo 7, imagem 1 %32
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Microphone Replacement: passo 8, imagem 1 %32
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Microphone Replacement: passo 9, imagem 1 %32 Samsung Eternity Microphone Replacement: passo 9, imagem 2 %32 Samsung Eternity Microphone Replacement: passo 9, imagem 3 %32
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Microphone Replacement: passo 10, imagem 1 %32
    • You have successfully removed the motherboard from the phone.
  10. Samsung Eternity Microphone Replacement, Digitizer and Screen: passo 11, imagem 1 %32
    • Flip the phone over so you are looking at the front screen of the phone.
  11. Samsung Eternity Microphone Replacement: passo 12, imagem 1 %32 Samsung Eternity Microphone Replacement: passo 12, imagem 2 %32 Samsung Eternity Microphone Replacement: passo 12, imagem 3 %32
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
    • This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
  12. Samsung Eternity Microphone Replacement: passo 13, imagem 1 %32 Samsung Eternity Microphone Replacement: passo 13, imagem 2 %32 Samsung Eternity Microphone Replacement: passo 13, imagem 3 %32
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
  13. Samsung Eternity Microphone Replacement, Microphone: passo 14, imagem 1 %32
    • Pop the microphone up and out of its small housing.
  14. Samsung Eternity Microphone Replacement: passo 15, imagem 1 %32
    • Peel up the black tape on the bottom of the back case.
  15. Samsung Eternity Microphone Replacement: passo 16, imagem 1 %32
    • Use the spudger to release the front buttons from the phones frame.
    • Don't try and pull the front buttons completely away from the phone. There are clips that still are holding them to the phone.
  16. Samsung Eternity Microphone Replacement: passo 17, imagem 1 %32 Samsung Eternity Microphone Replacement: passo 17, imagem 2 %32 Samsung Eternity Microphone Replacement: passo 17, imagem 3 %32
    • Use the spudger to remove three plastic lasso hooks that are holding the front buttons to the case.
    • The front button plastic assembly should come right off.
  17. Samsung Eternity Microphone Replacement: passo 18, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to release the button logic board away from the phone's casing.
    • Do not try and completely remove the component. There are logic ribbons that need to be guided through the phone's back casing.
  18. Samsung Eternity Microphone Replacement: passo 19, imagem 1 %32
    • You should be able to see two cables connected to the front button board.
    • Carefully slide these two cables through their respective holes in the body of the camera.
  19. Samsung Eternity Microphone Replacement: passo 20, imagem 1 %32
    • The front button board should slide out. At this time you can replace the button/microphone component.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 15-11, Regan Spring 2011 Membro de Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 47
Ao todo: 2,430
