Ir para o conteúdo principal
Samsung Eternity Digitizer and Screen Replacement
O que você precisa
    • Remove the back battery cover.
    Pergunte ao FixBot
    Comentar
  1. Samsung Eternity Digitizer and Screen Replacement: passo 2, imagem 1 %32
    • Using a nylon spudger, remove the phone's battery.
    Pergunte ao FixBot
    Comentar
  2. Samsung Eternity Digitizer and Screen Replacement: passo 3, imagem 1 %32
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Samsung Eternity Digitizer and Screen Replacement: passo 4, imagem 1 %32 Samsung Eternity Digitizer and Screen Replacement: passo 4, imagem 2 %32
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
    Pergunte ao FixBot
    Comentar
  4. Samsung Eternity Digitizer and Screen Replacement, Motherboard: passo 5, imagem 1 %32
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
    Pergunte ao FixBot
    Comentar
  5. Samsung Eternity Digitizer and Screen Replacement: passo 6, imagem 1 %32 Samsung Eternity Digitizer and Screen Replacement: passo 6, imagem 2 %32 Samsung Eternity Digitizer and Screen Replacement: passo 6, imagem 3 %32
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
    Pergunte ao FixBot
    Comentar
  6. Samsung Eternity Digitizer and Screen Replacement: passo 7, imagem 1 %32
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
    Pergunte ao FixBot
    Comentar
  7. Samsung Eternity Digitizer and Screen Replacement: passo 8, imagem 1 %32
    • Peel the button sensor on the side of the motherboard off of the case.
    Pergunte ao FixBot
    Comentar
  8. Samsung Eternity Digitizer and Screen Replacement: passo 9, imagem 1 %32 Samsung Eternity Digitizer and Screen Replacement: passo 9, imagem 2 %32 Samsung Eternity Digitizer and Screen Replacement: passo 9, imagem 3 %32
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
    Pergunte ao FixBot
    Comentar
  9. Samsung Eternity Digitizer and Screen Replacement: passo 10, imagem 1 %32
    • You have successfully removed the motherboard from the phone.
    Pergunte ao FixBot
    Comentar
  10. Samsung Eternity Digitizer and Screen Replacement, Digitizer and Screen: passo 11, imagem 1 %32
    • Flip the phone over so you are looking at the front screen of the phone.
    Pergunte ao FixBot
    Comentar
  11. Samsung Eternity Digitizer and Screen Replacement: passo 12, imagem 1 %32 Samsung Eternity Digitizer and Screen Replacement: passo 12, imagem 2 %32 Samsung Eternity Digitizer and Screen Replacement: passo 12, imagem 3 %32
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
    • This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
    Pergunte ao FixBot
    Comentar
  12. Samsung Eternity Digitizer and Screen Replacement: passo 13, imagem 1 %32 Samsung Eternity Digitizer and Screen Replacement: passo 13, imagem 2 %32 Samsung Eternity Digitizer and Screen Replacement: passo 13, imagem 3 %32
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 15-11, Regan Spring 2011 Membro de Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Membros
Autoria de 14 guias
3Comentários do guia
You did not mention how to glue the digitizer to LCD. That is a very important step.
cashyapan - Responder Compartilhar
Do these steps also work for the Samsung Eternity 2?
Brian Coukis The 90's Kid! - Responder Compartilhar
Está mierda no sale
Luz esther Martinez Pérez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 40
Ao todo: 7,295
