Ir para o conteúdo principal
Samsung Epix Speakers Replacement
O que você precisa
  1. Samsung Epix Speakers Replacement, Battery: passo 1, imagem 1 %32
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix Speakers Replacement: passo 2, imagem 1 %32
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix Speakers Replacement, Speakers: passo 3, imagem 1 %32
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Samsung Epix Speakers Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Speakers Replacement: passo 5, imagem 1 %32 Samsung Epix Speakers Replacement: passo 5, imagem 2 %32
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Speakers Replacement: passo 6, imagem 1 %32
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
  7. Samsung Epix Speakers Replacement: passo 7, imagem 1 %32
    • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
    • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
  8. Samsung Epix Speakers Replacement: passo 8, imagem 1 %32
    • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
  9. Samsung Epix Speakers Replacement: passo 9, imagem 1 %32
    • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
    • Lift the speaker off of the motherboard.
    • The camera will remain attached to the phone when removing the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Fernando Lamas
Membro desde: 04/20/11
35 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-15, Regan Spring 2011 Membro de Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 1,404
