Ir para o conteúdo principal
Samsung Epix Motherboard Replacement
O que você precisa
  1. Samsung Epix Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    Pergunte ao FixBot
    Comentar
  2. Samsung Epix Motherboard Replacement: passo 2, imagem 1 %32
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    Pergunte ao FixBot
    Comentar
  3. Samsung Epix Motherboard Replacement, Speakers: passo 3, imagem 1 %32
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
    Pergunte ao FixBot
    Comentar
  4. Samsung Epix Motherboard Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
    Pergunte ao FixBot
    Comentar
  5. Samsung Epix Motherboard Replacement: passo 5, imagem 1 %32 Samsung Epix Motherboard Replacement: passo 5, imagem 2 %32
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  6. Samsung Epix Motherboard Replacement: passo 6, imagem 1 %32
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Samsung Epix Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
    • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
    Pergunte ao FixBot
    Comentar
  8. Samsung Epix Motherboard Replacement: passo 8, imagem 1 %32
    • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Samsung Epix Motherboard Replacement: passo 9, imagem 1 %32
    • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
    • Lift the speaker off of the motherboard.
    • The camera will remain attached to the phone when removing the speaker.
    Pergunte ao FixBot
    Comentar
  10. Samsung Epix Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Using an iFixit opening tool, unlatch and disconnect the camera ribbon cable.
    Pergunte ao FixBot
    Comentar
  11. Samsung Epix Motherboard Replacement: passo 11, imagem 1 %32
    • Unlatch the LCD ribbon cable on the left side of the motherboard using the opening tool.
    Pergunte ao FixBot
    Comentar
  12. Samsung Epix Motherboard Replacement: passo 12, imagem 1 %32 Samsung Epix Motherboard Replacement: passo 12, imagem 2 %32
    • Unlatch and disconnect the two ribbon cables at the bottom center of the motherboard.
    • The two disconnected ribbon cables connect to the keypad and center button.
    Pergunte ao FixBot
    Comentar
  13. Samsung Epix Motherboard Replacement: passo 13, imagem 1 %32
    • Unlatch and remove the front panel ribbon cable located at the bottom right of the motherboard.
    Pergunte ao FixBot
    Comentar
  14. Samsung Epix Motherboard Replacement: passo 14, imagem 1 %32
    • Use the opening tool to gently disconnect the microphone cable, also located at the bottom right of the motherboard.
    Pergunte ao FixBot
    Comentar
  15. Samsung Epix Motherboard Replacement: passo 15, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the 3.5 mm screw at the bottom center of the motherboard.
    Pergunte ao FixBot
    Comentar
  16. Samsung Epix Motherboard Replacement: passo 16, imagem 1 %32
    • Carefully lift the motherboard from the left side to begin removing it from the phone chassis.
    • A ribbon cable is still connected underneath on the right side.
    Pergunte ao FixBot
    Comentar
  17. Samsung Epix Motherboard Replacement: passo 17, imagem 1 %32
    • Flip the motherboard slightly to access the back, then use the opening tool to unlatch and disconnect the remaining ribbon cable.
    • Remove the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Mark Wyse
Membro desde: 04/19/11
62 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-15, Regan Spring 2011 Membro de Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 48
Ao todo: 1,960
