Ir para o conteúdo principal
Samsung Epix LCD Display Replacement
O que você precisa
  1. Samsung Epix LCD Display Replacement, Battery: passo 1, imagem 1 %32
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix LCD Display Replacement: passo 2, imagem 1 %32
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix LCD Display Replacement, LCD Display: passo 3, imagem 1 %32
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
  4. Samsung Epix LCD Display Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
  5. Samsung Epix LCD Display Replacement: passo 5, imagem 1 %32 Samsung Epix LCD Display Replacement: passo 5, imagem 2 %32
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix LCD Display Replacement: passo 6, imagem 1 %32
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
  7. Samsung Epix LCD Display Replacement: passo 7, imagem 1 %32
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
  8. Samsung Epix LCD Display Replacement: passo 8, imagem 1 %32
    • Remove the front faceplate by lifting it off of the phone chassis.
  9. Samsung Epix LCD Display Replacement: passo 9, imagem 1 %32
    • Using the opening tool, unlatch the LCD ribbon cable.
  10. Samsung Epix LCD Display Replacement: passo 10, imagem 1 %32
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
  11. Samsung Epix LCD Display Replacement: passo 11, imagem 1 %32
    • Lift the LCD display out from phone chassis.
Conclusão
Uma outra pessoa concluiu este guia.
Mark Wyse
Membro desde: 04/19/11
59 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-15, Regan Spring 2011 Membro de Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,913
