Ir para o conteúdo principal
Samsung Epix LCD Display Replacement
O que você precisa
  1. Samsung Epix LCD Display Replacement, Battery: passo 1, imagem 1 %32
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    Pergunte ao FixBot
    Comentar
  2. Samsung Epix LCD Display Replacement: passo 2, imagem 1 %32
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    Pergunte ao FixBot
    Comentar
  3. Samsung Epix LCD Display Replacement, LCD Display: passo 3, imagem 1 %32
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
    Pergunte ao FixBot
    Comentar
  4. Samsung Epix LCD Display Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
    Pergunte ao FixBot
    Comentar
  5. Samsung Epix LCD Display Replacement: passo 5, imagem 1 %32 Samsung Epix LCD Display Replacement: passo 5, imagem 2 %32
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  6. Samsung Epix LCD Display Replacement: passo 6, imagem 1 %32
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Samsung Epix LCD Display Replacement: passo 7, imagem 1 %32
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
    Pergunte ao FixBot
    Comentar
  8. Samsung Epix LCD Display Replacement: passo 8, imagem 1 %32
    • Remove the front faceplate by lifting it off of the phone chassis.
    Pergunte ao FixBot
    Comentar
  9. Samsung Epix LCD Display Replacement: passo 9, imagem 1 %32
    • Using the opening tool, unlatch the LCD ribbon cable.
    Pergunte ao FixBot
    Comentar
  10. Samsung Epix LCD Display Replacement: passo 10, imagem 1 %32
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
    Pergunte ao FixBot
    Comentar
  11. Samsung Epix LCD Display Replacement: passo 11, imagem 1 %32
    • Lift the LCD display out from phone chassis.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Mark Wyse
Membro desde: 04/19/11
62 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-15, Regan Spring 2011 Membro de Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 39
Ao todo: 2,235
