Ir para o conteúdo principal
Samsung Epic 4G Touch microSD Card Replacement
O que você precisa
  1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Epic 4G Touch microSD Card Replacement, Rear Case: passo 1, imagem 2 %32
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch microSD Card Replacement: passo 2, imagem 1 %32 Samsung Epic 4G Touch microSD Card Replacement: passo 2, imagem 2 %32
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: passo 3, imagem 1 %32 Samsung Epic 4G Touch microSD Card Replacement, microSD Card: passo 3, imagem 2 %32
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch microSD Card Replacement: passo 4, imagem 1 %32
    • Pull the microSD card away from its slot.
Conclusão
3 outras pessoas executaram este guia.
2 comentários
Uhh.... my Australian SGSII looks different to this...
Bonj - Responder
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 4,356
