Ir para o conteúdo principal
Samsung Epic 4G Touch Front Panel Assembly Replacement
O que você precisa
  1. Samsung Epic 4G Touch Front Panel Assembly Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement, Rear Case: passo 1, imagem 2 %32
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 2, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 2, imagem 2 %32
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Front Panel Assembly Replacement, microSD Card: passo 3, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement, microSD Card: passo 3, imagem 2 %32
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 4, imagem 1 %32
    • Pull the microSD card away from its slot.
  5. Samsung Epic 4G Touch Front Panel Assembly Replacement, Battery: passo 5, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement, Battery: passo 5, imagem 2 %32
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  6. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 6, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 6, imagem 2 %32
    • Lift and remove the battery from the midframe.
  7. Samsung Epic 4G Touch Front Panel Assembly Replacement, Plastic Midframe: passo 7, imagem 1 %32
    • Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
  8. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 8, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 8, imagem 2 %32
    • Unless you pry at the right insertion points, you might have a difficult time removing the midframe. This shot of the display assembly, with display glass facing down, is meant to help you locate them.
    • The first insertion point is a divot to the left of the micro-USB port.
    • The second insertion point is a divot to the right of the micro-USB port near the corner of the phone.
    • The final insertion point is located about two inches to the right of the volume control toggle, toward the corner of the phone. An additional insertion point is located slightly to the right of the volume button if you need it.
  9. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 9, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 9, imagem 2 %32
    • Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap.
  10. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 10, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 10, imagem 2 %32
    • Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap.
  11. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 11, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 11, imagem 2 %32
    • Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly.
  12. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 12, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 12, imagem 2 %32
    • Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely.
  13. Samsung Epic 4G Touch Front Panel Assembly Replacement, Motherboard Connectors: passo 13, imagem 1 %32
    • Headphone jack/vibrator assembly cable connector
    • Front-facing camera cable connector
    • Digitizer cable connector
    • Display cable connector
  14. Samsung Epic 4G Touch Front Panel Assembly Replacement, Headphone Jack/Vibrator Connector: passo 14, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement, Headphone Jack/Vibrator Connector: passo 14, imagem 2 %32
    • Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable.
  15. Samsung Epic 4G Touch Front Panel Assembly Replacement, Motherboard Assembly: passo 15, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement, Motherboard Assembly: passo 15, imagem 2 %32
    • Use the flat end of a spudger to disconnect the front-facing camera cable connector.
  16. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 16, imagem 1 %32
    • Carefully disconnect the digitizer display cable.
  17. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 17, imagem 1 %32
    • Use a spudger to disconnect the display cable connector.
  18. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 18, imagem 1 %32
    • Remove the two 3 mm Phillips #00 screws.
  19. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 19, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 19, imagem 2 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 19, imagem 3 %32
    • Lift the micro-USB end of the motherboard away from the display assembly and pull it down.
    • Be mindful that you don't snag the motherboard on any cables as you remove it.
  20. Samsung Epic 4G Touch Front Panel Assembly Replacement, Microphone Cover: passo 20, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement, Microphone Cover: passo 20, imagem 2 %32
    • The microphone cover fits in a notch and over a small peg in the display assembly, ensure it is well seated before sealing your device.
    • Make sure the microphone cover stays in its slot on the display assembly.
    • When you removed the motherboard, the microphone cover may have remained stuck on the microphone. Put it back in its notch in the display assembly to avoid losing it.
  21. Samsung Epic 4G Touch Front Panel Assembly Replacement, Front Facing Camera/Earpiece Speaker Assembly: passo 21, imagem 1 %32
    • Remove the 2.3 mm Phillips #00 screw securing the front-facing camera bracket to the display assembly.
  22. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 22, imagem 1 %32
    • Remove the front-facing camera bracket from the display assembly.
  23. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 23, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 23, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, or your fingers, remove the front-facing camera/earpiece speaker assembly.
  24. Samsung Epic 4G Touch Front Panel Assembly Replacement, Headphone Jack/Vibrator: passo 24, imagem 1 %32 Samsung Epic 4G Touch Front Panel Assembly Replacement, Headphone Jack/Vibrator: passo 24, imagem 2 %32
    • Insert the pointed end of a spudger into the gap in the corner of the midframe to free the vibrator from the adhesive.
    • Do not completely remove the vibrator, it is still attached to the headphone jack/vibrator assembly and can only come out with the rest of the unit.
  25. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 25, imagem 1 %32
    • Use the flat end of a spudger to release the headphone jack from the adhesive securing it to the midframe.
  26. Samsung Epic 4G Touch Front Panel Assembly Replacement: passo 26, imagem 1 %32
    • Remove the headphone jack/vibrator assembly from the display assembly.
  27. Samsung Epic 4G Touch Front Panel Assembly Replacement, Front Panel Assembly: passo 27, imagem 1 %32
    • Front panel assembly remains.
Conclusão
17 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
467.548 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.065 guias
2 comentários
My display is broken but the touch screen still works. How do you replace the display?
atworktom - Responder
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
Edward Weissbard - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 19,353
