Ir para o conteúdo principal
Samsung Epic 4G Touch Battery Replacement
O que você precisa
  1. Samsung Epic 4G Touch Battery Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Epic 4G Touch Battery Replacement, Rear Case: passo 1, imagem 2 %32
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Battery Replacement: passo 2, imagem 1 %32 Samsung Epic 4G Touch Battery Replacement: passo 2, imagem 2 %32
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Battery Replacement, Battery: passo 3, imagem 1 %32 Samsung Epic 4G Touch Battery Replacement, Battery: passo 3, imagem 2 %32
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  4. Samsung Epic 4G Touch Battery Replacement: passo 4, imagem 1 %32 Samsung Epic 4G Touch Battery Replacement: passo 4, imagem 2 %32
    • Lift and remove the battery from the midframe.
Conclusão
10 outras pessoas executaram este guia.
2 comentários
i just reacently got my phone and I don't know whats happening to it. it keeps turning itself off. iv factory reset it 2 times. should I replace the phone or just the battery. I have a Samsung galaxy s II. (sprint)
gamerzzz - Responder
I have an samsung galaxy s2 gsm unlocked and my battery wont stay charge and sometimes when its plugged in a charger it decreases instead of increasing and if it does charges it decrease fast what shall i do shall i get a new battery or replace the phone
ianasims - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 9,749
