Ir para o conteúdo principal
Samsung Epic 4G Camera Lens Replacement
O que você precisa
  1. Samsung Epic 4G Camera Lens Replacement, Phone Case: passo 1, imagem 1 %32
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Camera Lens Replacement: passo 2, imagem 1 %32
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Camera Lens Replacement, Battery: passo 3, imagem 1 %32
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Camera Lens Replacement, Removing the Memory Card:: passo 4, imagem 1 %32
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Camera Lens Replacement, Removing the Back Housing: passo 5, imagem 1 %32 Samsung Epic 4G Camera Lens Replacement, Removing the Back Housing: passo 5, imagem 2 %32
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Camera Lens Replacement, Removing the Power Button: passo 6, imagem 1 %32 Samsung Epic 4G Camera Lens Replacement, Removing the Power Button: passo 6, imagem 2 %32
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
  7. Samsung Epic 4G Camera Lens Replacement, Micro USB Port: passo 7, imagem 1 %32
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
  8. Samsung Epic 4G Camera Lens Replacement, Removing the Antenna Assembly: passo 8, imagem 1 %32 Samsung Epic 4G Camera Lens Replacement, Removing the Antenna Assembly: passo 8, imagem 2 %32
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
  9. Samsung Epic 4G Camera Lens Replacement, Removing the Flex Cable: passo 9, imagem 1 %32 Samsung Epic 4G Camera Lens Replacement, Removing the Flex Cable: passo 9, imagem 2 %32
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
  10. Samsung Epic 4G Camera Lens Replacement: passo 10, imagem 1 %32
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
  11. Samsung Epic 4G Camera Lens Replacement, Camera Lens: passo 11, imagem 1 %32
    • Remove and replace the camera lens with a new one from a manufacturer.
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 24-25, Regan Fall 2012 Membro de Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 951
