Ir para o conteúdo principal
Samsung Droid Charge SIM Card Port Replacement
O que você precisa
  1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: passo 1, imagem 1 %32
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Samsung Droid Charge SIM Card Port Replacement, Battery: passo 2, imagem 1 %32
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
  3. Samsung Droid Charge SIM Card Port Replacement, microSD: passo 3, imagem 1 %32
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
  4. Samsung Droid Charge SIM Card Port Replacement, SIM Card: passo 4, imagem 1 %32
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
  5. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: passo 5, imagem 1 %32
    • Carefully remove the back cover.
    • Remove the two 5mm screws with a small Phillips head screwdriver.
  6. Samsung Droid Charge SIM Card Port Replacement: passo 6, imagem 1 %32
    • Removal of the back half of the casing.
    • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
    • Use a prying motion to lift the casing up. This will separate the phone casing.
    • Repeat this motion all around the screen edge until the casing pops off.
  7. Samsung Droid Charge SIM Card Port Replacement: passo 7, imagem 1 %32
    • Release the volume button flex cable on the right.
    • Release the pop connector on the motherboard located to the left of the SIM card port.
  8. Samsung Droid Charge SIM Card Port Replacement: passo 8, imagem 1 %32 Samsung Droid Charge SIM Card Port Replacement: passo 8, imagem 2 %32
    • Your SIM card port is now unattached.
    • Remove SIM card port from motherboard.
Conclusão
3 outras pessoas executaram este guia.
Lucas Carter
Membro desde: 09/27/12
172 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-44, Forte Fall 2012 Membro de Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Duração total: 2,394
