Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Press the eject button to insert the tray
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Unscrew the 3 screws in the back.
    • Unscrew the 3 screws in the back.
  4. Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
    • Pull the outer case upward and then towards you.
  5. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  7. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  8. Locate the white clip that attaches the cord to the motherboard Grasp clip and squeeze to release Lift up and remove power cord
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  9. Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray
    • Remove the three screws holding in the DVD tray
  10. Remove the power cord and first two ribbons by pulling them directly out of their sockets. Remove the power cord and first two ribbons by pulling them directly out of their sockets.
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  11. Gently lift the DVD tray off of the motherboard. Gently lift the DVD tray off of the motherboard.
    • Gently lift the DVD tray off of the motherboard.
  12. Unscrew the 2 screws on the motherboard Unscrew the 2 screws on the back
    • Unscrew the 2 screws on the motherboard
    • Unscrew the 2 screws on the back
  13. Disconnect the wires and ribbon by pulling them out of their respective connections Disconnect the wires and ribbon by pulling them out of their respective connections Disconnect the wires and ribbon by pulling them out of their respective connections
    • Disconnect the wires and ribbon by pulling them out of their respective connections
  14. Lift board up and out of the lower case Lift board up and out of the lower case
    • Lift board up and out of the lower case
  15. The LCD screen has pins attaching it to the motherboard.  Flip the motherboard over. De-solder LCD screen pins from the motherboard.
    • The LCD screen has pins attaching it to the motherboard. Flip the motherboard over.
    • De-solder LCD screen pins from the motherboard.
    • Pinch black tabs to remove LCD screen from motherboard.
    • Solder the new LCD screen pins into motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Evan Domingue
Membro desde: 28-01-2011
401 reputação
3 Guias de autoria
Equipe
Cal Poly, Team 3-30, Regan Winter 2011 Membro de Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Membros
8 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Todo: 2,756
