Ir para o conteúdo principal
Samsung DVD-P230 LCD Screen Replacement
O que você precisa
  1. Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: passo 1, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: passo 1, imagem 2 %32 Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: passo 1, imagem 3 %32
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
    Pergunte ao FixBot
  2. Samsung DVD-P230 LCD Screen Replacement: passo 2, imagem 1 %32
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
    Pergunte ao FixBot
  3. Samsung DVD-P230 LCD Screen Replacement: passo 3, imagem 1 %32
    • Unscrew the 3 screws in the back.
    Pergunte ao FixBot
  4. Samsung DVD-P230 LCD Screen Replacement: passo 4, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement: passo 4, imagem 2 %32
    • Pull the outer case upward and then towards you.
    Pergunte ao FixBot
  5. Samsung DVD-P230 LCD Screen Replacement: passo 5, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement: passo 5, imagem 2 %32 Samsung DVD-P230 LCD Screen Replacement: passo 5, imagem 3 %32
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
    Pergunte ao FixBot
  6. Samsung DVD-P230 LCD Screen Replacement: passo 6, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement: passo 6, imagem 2 %32
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
    Pergunte ao FixBot
  7. Samsung DVD-P230 LCD Screen Replacement, Power Cord: passo 7, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement, Power Cord: passo 7, imagem 2 %32 Samsung DVD-P230 LCD Screen Replacement, Power Cord: passo 7, imagem 3 %32
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
    Pergunte ao FixBot
  8. Samsung DVD-P230 LCD Screen Replacement, Tray: passo 8, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement, Tray: passo 8, imagem 2 %32 Samsung DVD-P230 LCD Screen Replacement, Tray: passo 8, imagem 3 %32
    • Remove the three screws holding in the DVD tray
    Pergunte ao FixBot
  9. Samsung DVD-P230 LCD Screen Replacement: passo 9, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement: passo 9, imagem 2 %32
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
    Pergunte ao FixBot
  10. Samsung DVD-P230 LCD Screen Replacement: passo 10, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement: passo 10, imagem 2 %32
    • Gently lift the DVD tray off of the motherboard.
    Pergunte ao FixBot
  11. Samsung DVD-P230 LCD Screen Replacement, Motherboard: passo 11, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement, Motherboard: passo 11, imagem 2 %32
    • Unscrew the 2 screws on the motherboard
    • Unscrew the 2 screws on the back
    Pergunte ao FixBot
  12. Samsung DVD-P230 LCD Screen Replacement: passo 12, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement: passo 12, imagem 2 %32 Samsung DVD-P230 LCD Screen Replacement: passo 12, imagem 3 %32
    • Disconnect the wires and ribbon by pulling them out of their respective connections
    Pergunte ao FixBot
  13. Samsung DVD-P230 LCD Screen Replacement: passo 13, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement: passo 13, imagem 2 %32
    • Lift board up and out of the lower case
    Pergunte ao FixBot
  14. Samsung DVD-P230 LCD Screen Replacement, LCD Screen: passo 14, imagem 1 %32 Samsung DVD-P230 LCD Screen Replacement, LCD Screen: passo 14, imagem 2 %32
    • The LCD screen has pins attaching it to the motherboard. Flip the motherboard over.
    • De-solder LCD screen pins from the motherboard.
    • Pinch black tabs to remove LCD screen from motherboard.
    • Solder the new LCD screen pins into motherboard.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
Evan Domingue
Membro desde: 01/28/11
410 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-30, Regan Winter 2011 Membro de Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 62
Ao todo: 3,304
