Ir para o conteúdo principal
Samsung DVD-HD850 Player Disk Tray Replacement
O que você precisa
  1. Samsung DVD-HD850 Player Disk Tray Replacement, Locate and Remove The Disk Tray: passo 1, imagem 1 %32
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  2. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Data Strips: passo 2, imagem 1 %32
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  3. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: passo 3, imagem 1 %32 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: passo 3, imagem 2 %32 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: passo 3, imagem 3 %32
    • As noted by the red circles, locate and remove the screws one at a time
  4. Samsung DVD-HD850 Player Disk Tray Replacement, Disk Tray Removal: passo 4, imagem 1 %32
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  5. Samsung DVD-HD850 Player Disk Tray Replacement, Success!: passo 5, imagem 1 %32
    • Congrats! You have sucessfully have taken out the disk drive
Conclusão
Uma outra pessoa concluiu este guia.
Carlos
Membro desde: 10/16/14
354 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Membro de UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 555
