Ir para o conteúdo principal
Samsung DVD-HD850 Player Cover Replacement
O que você precisa
  1. Samsung DVD-HD850 Player Cover Replacement, Cover: passo 1, imagem 1 %32
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Cover Replacement, Locate and remove screws: passo 2, imagem 1 %32
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Cover Replacement, Remove Cover: passo 3, imagem 1 %32
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
Conclusão
Uma outra pessoa concluiu este guia.
Devon Clements
Membro desde: 10/21/14
228 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Membro de UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 373
