Ir para o conteúdo principal
Samsung DV300F Lens Replacement
O que você precisa
  1. Samsung DV300F Lens Replacement, Front and Rear Casing: passo 1, imagem 1 %32 Samsung DV300F Lens Replacement, Front and Rear Casing: passo 1, imagem 2 %32 Samsung DV300F Lens Replacement, Front and Rear Casing: passo 1, imagem 3 %32
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Lens Replacement: passo 2, imagem 1 %32 Samsung DV300F Lens Replacement: passo 2, imagem 2 %32
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Lens Replacement: passo 3, imagem 1 %32 Samsung DV300F Lens Replacement: passo 3, imagem 2 %32 Samsung DV300F Lens Replacement: passo 3, imagem 3 %32
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Lens Replacement, Back Button Control: passo 4, imagem 1 %32 Samsung DV300F Lens Replacement, Back Button Control: passo 4, imagem 2 %32
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Lens Replacement, Back LCD Screen: passo 5, imagem 1 %32
    • Remove the back LCD screen from its place carefully.
  6. Samsung DV300F Lens Replacement: passo 6, imagem 1 %32 Samsung DV300F Lens Replacement: passo 6, imagem 2 %32
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Lens Replacement, Lens: passo 7, imagem 1 %32 Samsung DV300F Lens Replacement, Lens: passo 7, imagem 2 %32
    • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
    • Remove the circuit board cover
  8. Samsung DV300F Lens Replacement: passo 8, imagem 1 %32 Samsung DV300F Lens Replacement: passo 8, imagem 2 %32
    • Flip the first black tab connecting the lens to the circuit board
    • Flip the second black tab connecting the lens to the circuit board
    • Push the lens out from the front to remove it from the camera
Conclusão
5 outras pessoas executaram este guia.
Timothy Gordon
Membro desde: 03/23/15
820 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 5-10, Williams Spring 2015 Membro de Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
Membros da 3
Autoria de 10 guias
Um comentário
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 38
Duração total: 1,789
