Ir para o conteúdo principal
Samsung DV300F Front and Rear Casing Replacement
O que você precisa
  1. Samsung DV300F Front and Rear Casing Replacement, Front and Rear Casing: passo 1, imagem 1 %32 Samsung DV300F Front and Rear Casing Replacement, Front and Rear Casing: passo 1, imagem 2 %32 Samsung DV300F Front and Rear Casing Replacement, Front and Rear Casing: passo 1, imagem 3 %32
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Front and Rear Casing Replacement: passo 2, imagem 1 %32 Samsung DV300F Front and Rear Casing Replacement: passo 2, imagem 2 %32
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Front and Rear Casing Replacement: passo 3, imagem 1 %32 Samsung DV300F Front and Rear Casing Replacement: passo 3, imagem 2 %32 Samsung DV300F Front and Rear Casing Replacement: passo 3, imagem 3 %32
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
Conclusão
Timothy Gordon
Membro desde: 03/23/15
820 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 5-10, Williams Spring 2015 Membro de Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 486
