Ir para o conteúdo principal
Samsung DV180F Repair Display Screen Replacement
O que você precisa
  1. Samsung DV180F Repair Display Screen Replacement, Display Screen: passo 1, imagem 1 %32 Samsung DV180F Repair Display Screen Replacement, Display Screen: passo 1, imagem 2 %32 Samsung DV180F Repair Display Screen Replacement, Display Screen: passo 1, imagem 3 %32
    • Use a pry tool to push the highlighted blue latch away from the battery in the direction of the arrow. Remove the battery.
    • Use the Phillips 000 Bit to remove all screws from the perimeter of the device. Set aside.
    • Use a small Plastic Opening Tool at the seam by the Micro USB plug. Separate the plastic case from the device.
  2. Samsung DV180F Repair Display Screen Replacement: passo 2, imagem 1 %32 Samsung DV180F Repair Display Screen Replacement: passo 2, imagem 2 %32
    • Remove the outer casing holding the back part of the camera together. Leave on the front casing.
    • Use a Phillips screwdriver to remove the two small screws holding the outer casing to the mother board.
    • Use the prying tool to unhook the casing from the plate covering the motherboard
  3. Samsung DV180F Repair Display Screen Replacement: passo 3, imagem 1 %32 Samsung DV180F Repair Display Screen Replacement: passo 3, imagem 2 %32 Samsung DV180F Repair Display Screen Replacement: passo 3, imagem 3 %32
    • Release the ribbon from the button casing connected to the motherboard.
    • Hold the metal casing out of the way and snap the ribbon connector back. Remove the display screen ribbon attached.
    • Replace the screen then repeat all of these steps in reverse order to reassemble.
Conclusão
Evan McGettrick
Membro desde: 09/24/16
190 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 14-4, Eyestone Fall 2016 Membro de USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
Membros da 4
Autoria de 8 guias
2 comentários
I got it open in the hope of finding a screen ID. I can not find a replacement screen for the DV180F. do you know if the DV150 screen will work?
lrrpbill68 - Responder
im looking for a screen as well were you able to find a replacement?
Sidath Paranavithane -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 483
