Ir para o conteúdo principal
Samsung DV180F Repair Battery Replacement
O que você precisa
  1. Samsung DV180F Repair Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung DV180F Repair Battery Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery door and slide it to the right to unlatch it. Swing the battery door up to expose the battery chamber.
    • Ensure that the camera is turned off before attempting to replace the battery.
  2. Samsung DV180F Repair Battery Replacement: passo 2, imagem 1 %32
    • Locate the blue latch that holds the battery in the battery chamber. Using your fingernail or a plastic opening tool, push it away from the battery, in the direction of the arrow on the latch.
  3. Samsung DV180F Repair Battery Replacement: passo 3, imagem 1 %32 Samsung DV180F Repair Battery Replacement: passo 3, imagem 2 %32
    • Once the latch is disengaged, the battery should pop up. Grab the battery and slide it up and out of the camera.
  4. Samsung DV180F Repair Battery Replacement: passo 4, imagem 1 %32
    • Move the blue latch out of the way and slide the replacement battery into the battery chamber. Lightly push until the battery clicks in place. Close the battery door.
    • Make sure that the replacement battery is oriented correctly.
Conclusão
maria
Membro desde: 09/26/16
244 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-4, Eyestone Fall 2016 Membro de USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 371
