Ir para o conteúdo principal
Samsung DV180F Repair Back control buttons Replacement
O que você precisa
  1. Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: passo 1, imagem 1 %32 Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: passo 1, imagem 2 %32
    • Ensure the camera is turned off and battery is taken out before you begin.
    • Remove the two external screws from the camera using a Phillips 000 screwdriver.
  2. Samsung DV180F Repair Back control buttons Replacement: passo 2, imagem 1 %32
    • Insert a plastic opening tool in the gap between the camera body and back panel.
    • Pry along the right side of the camera to separate the back panel.
  3. Samsung DV180F Repair Back control buttons Replacement: passo 3, imagem 1 %32
    • Once the camera is open, remove the two internal screws using a Phillips 000 screwdriver.
  4. Samsung DV180F Repair Back control buttons Replacement: passo 4, imagem 1 %32 Samsung DV180F Repair Back control buttons Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to release the lock securing the ribbon receptor to the right side of the motherboard.
    • Ribbons have to be unlocked before removal to prevent damage.
  5. Samsung DV180F Repair Back control buttons Replacement: passo 5, imagem 1 %32
    • Gently lift the circuit board from the camera.
    • Remove the display ribbon receptor lock to remove back panel from the motherboard.
  6. Samsung DV180F Repair Back control buttons Replacement: passo 6, imagem 1 %32 Samsung DV180F Repair Back control buttons Replacement: passo 6, imagem 2 %32
    • Remove back display.
    • Replace the back button panel.
Conclusão
maria
Membro desde: 09/26/16
244 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-4, Eyestone Fall 2016 Membro de USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 354
