Ir para o conteúdo principal
Samsung Chromebook XE550C22 Wifi Card Replacement
O que você precisa
  1. Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: passo 1, imagem 2 %32 Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: passo 1, imagem 3 %32
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 Wifi Card Replacement: passo 2, imagem 1 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 2, imagem 2 %32
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 Wifi Card Replacement: passo 3, imagem 1 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 3, imagem 2 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 3, imagem 3 %32
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 Wifi Card Replacement: passo 4, imagem 1 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 4, imagem 2 %32
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 Wifi Card Replacement, Battery: passo 5, imagem 1 %32 Samsung Chromebook XE550C22 Wifi Card Replacement, Battery: passo 5, imagem 2 %32
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 Wifi Card Replacement: passo 6, imagem 1 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 6, imagem 2 %32
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 Wifi Card Replacement, Wifi Card: passo 7, imagem 1 %32
    • Locate the wifi card on the top left of the Chromebook.
  8. Samsung Chromebook XE550C22 Wifi Card Replacement: passo 8, imagem 1 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 8, imagem 2 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 8, imagem 3 %32
    • Use only plastic tools for this step.
    • Use the spudger to detach the black and white cords from the wifi card.
  9. Samsung Chromebook XE550C22 Wifi Card Replacement: passo 9, imagem 1 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 9, imagem 2 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 9, imagem 3 %32
    • Remove the 6mm screw from the top right corner of the card using the J0 screwdriver.
    • The wifi card will "pop-up".
  10. Samsung Chromebook XE550C22 Wifi Card Replacement: passo 10, imagem 1 %32 Samsung Chromebook XE550C22 Wifi Card Replacement: passo 10, imagem 2 %32
    • Using your hands, gently remove the card up and away from the Chromebook.
Conclusão
5 outras pessoas executaram este guia.
Linh Luu
Membro desde: 09/11/17
312 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 31
Duração total: 4,098
