Ir para o conteúdo principal
Samsung Chromebook XE550C22 Speakers Replacement
O que você precisa
  1. Samsung Chromebook XE550C22 Speakers Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Chromebook XE550C22 Speakers Replacement, Back Panel: passo 1, imagem 2 %32 Samsung Chromebook XE550C22 Speakers Replacement, Back Panel: passo 1, imagem 3 %32
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 Speakers Replacement: passo 2, imagem 1 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 2, imagem 2 %32
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 Speakers Replacement: passo 3, imagem 1 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 3, imagem 2 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 3, imagem 3 %32
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 Speakers Replacement: passo 4, imagem 1 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 4, imagem 2 %32
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 Speakers Replacement, Battery: passo 5, imagem 1 %32 Samsung Chromebook XE550C22 Speakers Replacement, Battery: passo 5, imagem 2 %32
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 Speakers Replacement: passo 6, imagem 1 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 6, imagem 2 %32
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 Speakers Replacement, Speakers: passo 7, imagem 1 %32
    • Locate the speakers on the bottom left and right sides of the Chromebook.
  8. Samsung Chromebook XE550C22 Speakers Replacement: passo 8, imagem 1 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 8, imagem 2 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the fine tipped tweezers, detach the white power clips from the motherboard.
    • This may require some force, but be careful not to damage the cables.
  9. Samsung Chromebook XE550C22 Speakers Replacement: passo 9, imagem 1 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 9, imagem 2 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 9, imagem 3 %32
    • Insert the prying tool between the speaker and the Chromebook.
    • Slide the prying tool under the full length of the speaker, severing the glue underneath.
    • This may take some force.
  10. Samsung Chromebook XE550C22 Speakers Replacement: passo 10, imagem 1 %32 Samsung Chromebook XE550C22 Speakers Replacement: passo 10, imagem 2 %32
    • Remove the speaker by lifting it up and away from the laptop.
Conclusão
Brenna Wolfe
Membro desde: 09/11/17
541 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 259
