Ir para o conteúdo principal
Samsung Chromebook Series 3 Speaker Replacement
O que você precisa
  1. Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: passo 1, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: passo 1, imagem 2 %32 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: passo 1, imagem 3 %32
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Speaker Replacement: passo 2, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 2, imagem 2 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 2, imagem 3 %32
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Speaker Replacement: passo 3, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 3, imagem 2 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 3, imagem 3 %32
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Speaker Replacement: passo 4, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 4, imagem 2 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 4, imagem 3 %32
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Speaker Replacement, Battery: passo 5, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement, Battery: passo 5, imagem 2 %32 Samsung Chromebook Series 3 Speaker Replacement, Battery: passo 5, imagem 3 %32
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Speaker Replacement: passo 6, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 6, imagem 2 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 6, imagem 3 %32
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Speaker Replacement: passo 7, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 7, imagem 2 %32
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Speaker Replacement, Speaker: passo 8, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement, Speaker: passo 8, imagem 2 %32 Samsung Chromebook Series 3 Speaker Replacement, Speaker: passo 8, imagem 3 %32
    • Disconnect the cable connecting the speakers to the motherboard by pulling on it away from the motherboard.
  9. Samsung Chromebook Series 3 Speaker Replacement: passo 9, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 9, imagem 2 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 9, imagem 3 %32
    • Lift up the piece of tape covering the trackpad ribbon cable.
    • Lift up the lock on the trackpad ribbon cable using a plastic opening tool.
    • Disconnect the trackpad ribbon cable by pulling it out.
  10. Samsung Chromebook Series 3 Speaker Replacement: passo 10, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 10, imagem 2 %32
    • Lift up the trackpad ribbon cable so that it is not covering the speaker wire.
    • Lift up the two pieces of metallic tape so that they no longer cover the speaker wire.
    • When reassembling the device, make sure to lay down the metallic tape in the same place it was prior to disassembly. The tape serves as a connector for certain electrical circuits that should not be disconnected.
  11. Samsung Chromebook Series 3 Speaker Replacement: passo 11, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 11, imagem 2 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 11, imagem 3 %32
    • Unscrew the four 3.7 mm screws holding down the speakers using a Phillips #00 screwdriver.
  12. Samsung Chromebook Series 3 Speaker Replacement: passo 12, imagem 1 %32 Samsung Chromebook Series 3 Speaker Replacement: passo 12, imagem 2 %32
    • Pull the speakers up to remove them.
Conclusão
7 outras pessoas executaram este guia.
Andrey Radchishin
Membro desde: 01/21/15
1.833 Reputação
Autoria de 4 guias
Equipe
UWT Liner: Group 1 Membro de UWT Liner: Group 1
Community
Membros da 5
Autoria de 8 guias
Um comentário
Many thanks.
Excellent guide .
Triumph Trident - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,573
