O que você precisa
Lay the Chromebook down so that the bottom cover is facing up.
Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
Pull out the battery partway in order to easily get to the battery connector.
Disconnect the cable connecting the speakers to the motherboard by pulling on it away from the motherboard.
7 outras pessoas executaram este guia.
