Ir para o conteúdo principal
Samsung Chromebook Series 3 Front Camera Replacement
O que você precisa
  1. Samsung Chromebook Series 3 Front Camera Replacement, Screen: passo 1, imagem 1 %32 Samsung Chromebook Series 3 Front Camera Replacement, Screen: passo 1, imagem 2 %32 Samsung Chromebook Series 3 Front Camera Replacement, Screen: passo 1, imagem 3 %32
    • Use the iFixit opening tool to get under the front cover and pop it out of place
  2. Samsung Chromebook Series 3 Front Camera Replacement: passo 2, imagem 1 %32 Samsung Chromebook Series 3 Front Camera Replacement: passo 2, imagem 2 %32 Samsung Chromebook Series 3 Front Camera Replacement: passo 2, imagem 3 %32
    • Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
    • Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
  3. Samsung Chromebook Series 3 Front Camera Replacement: passo 3, imagem 1 %32 Samsung Chromebook Series 3 Front Camera Replacement: passo 3, imagem 2 %32 Samsung Chromebook Series 3 Front Camera Replacement: passo 3, imagem 3 %32
    • Lift the lever to release the cable and pull the cable out.
  4. Samsung Chromebook Series 3 Front Camera Replacement: passo 4, imagem 1 %32
    • You can now remove the screen.
  5. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: passo 5, imagem 1 %32 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: passo 5, imagem 2 %32 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: passo 5, imagem 3 %32
    • Disconnect the ribbon cable connected to the front camera assembly.
    • You will need to flip up the little black lever to release the cable.
  6. Samsung Chromebook Series 3 Front Camera Replacement: passo 6, imagem 1 %32 Samsung Chromebook Series 3 Front Camera Replacement: passo 6, imagem 2 %32
    • Use an iFixit opening tool to pry the front camera assembly from the adhesive holding it in place.
Conclusão
Tyler Schultz
Membro desde: 03/25/19
555 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G1, Henning Spring 2019 Membro de IUPUI, Team S2-G1, Henning Spring 2019
IUPUI-HENNING-S19S2G1
Membros da 3
Autoria de 6 guias
Um comentário
Thanks for posting this! I looked all over youtube and couldn’t find anything so I am relieved to find this tutorial! I haven’t performed the repair yet, but I was wondering if removing the screen is necessary. From what I see, I can access the camera by just removing the bezel. Thanks for your feedback in advance!
Angel Knepper - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 419
