Ir para o conteúdo principal
Samsung Chromebook Series 3 Charging Port Replacement
O que você precisa
  1. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: passo 1, imagem 1 %32 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: passo 1, imagem 2 %32 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: passo 1, imagem 3 %32
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Charging Port Replacement: passo 2, imagem 1 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 2, imagem 2 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 2, imagem 3 %32
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Charging Port Replacement: passo 3, imagem 1 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 3, imagem 2 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 3, imagem 3 %32
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Charging Port Replacement: passo 4, imagem 1 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 4, imagem 2 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 4, imagem 3 %32
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: passo 5, imagem 1 %32 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: passo 5, imagem 2 %32 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: passo 5, imagem 3 %32
    • Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
  6. Samsung Chromebook Series 3 Charging Port Replacement: passo 6, imagem 1 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 6, imagem 2 %32
    • Remove the metal cover above the charging port module by pulling up and moving it slightly left.
  7. Samsung Chromebook Series 3 Charging Port Replacement: passo 7, imagem 1 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 7, imagem 2 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 7, imagem 3 %32
    • Pull out the charging port module connector by pulling directly up on it.
    • When reassembling, reconnect by positioning the connector directly above its original position and pushing down.
  8. Samsung Chromebook Series 3 Charging Port Replacement: passo 8, imagem 1 %32 Samsung Chromebook Series 3 Charging Port Replacement: passo 8, imagem 2 %32
    • You can now pull out the charging port module.
Conclusão
10 outras pessoas executaram este guia.
Andrey Radchishin
Membro desde: 01/21/15
1.833 Reputação
Autoria de 4 guias
Equipe
UWT Liner: Group 1 Membro de UWT Liner: Group 1
Community
Membros da 5
Autoria de 8 guias
2 comentários
What is the reference number for this charging port?
How to find it on ebay/other?
rafal - Responder
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
Andrey Radchishin -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 41
Duração total: 17,429
