Ir para o conteúdo principal
Samsung Chromebook Pro Hinge Replacement
O que você precisa
  1. Samsung Chromebook Pro Hinge Replacement, Hinge: passo 1, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement, Hinge: passo 1, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement, Hinge: passo 1, imagem 3 %32
    • Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
  2. Samsung Chromebook Pro Hinge Replacement: passo 2, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 2, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 2, imagem 3 %32
    • Slide the plastic opening tool in a corner at a steep angle, and lift up to remove the outer case.
  3. Samsung Chromebook Pro Hinge Replacement: passo 3, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 3, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the two white wires and one black wire. With the flat precision tweezers, untangle the white wires from the CONAN >PC+ABS< # 1-1.
    • Completely disconnect the black wire.
  4. Samsung Chromebook Pro Hinge Replacement: passo 4, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 4, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 4, imagem 3 %32
    • Remove the three 30 mm screws using the JIS J000 screw bit from the black CONAN >PC+ABS< # 1-1 plate.
    • Once all the screws are removed from the CONAN >PC+ABS< # 1-1 plate, remove the wire attached to underside and lift the plate to remove.
  5. Samsung Chromebook Pro Hinge Replacement: passo 5, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 5, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 5, imagem 3 %32
    • Locate hinge plates LP1 and RP1 on the top left and right corners of the Chromebook.
    • Remove the two 30 mm screws from hinge plates LP1 and RP1 using the JIS J000 screw bit.
  6. Samsung Chromebook Pro Hinge Replacement: passo 6, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 6, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 6, imagem 3 %32
    • On the right top corner, locate the black and gold wire.
    • Lift the bar that is locking the wire in using the precision tweezers.
    • Disconnect the wire by grasping the black portion with the precision tweezers, and then pulling away from the Chromebook Pro.
  7. Samsung Chromebook Pro Hinge Replacement: passo 7, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 7, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 7, imagem 3 %32
    • Completely open the Chromebook and gently separate both halves.
    • Be careful not to pull any wires.
  8. Samsung Chromebook Pro Hinge Replacement: passo 8, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 8, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 8, imagem 3 %32
    • Make sure the Chromebook is facing up.
    • Place the plastic opening tool at an angle in the gap between the hinge and Chromebook screen and lift up.
    • Completely remove the plastic screen lining using the plastic opening tool.
  9. Samsung Chromebook Pro Hinge Replacement: passo 9, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 9, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 9, imagem 3 %32
    • Remove the three 30 mm screws from hinge plate R1 and L1 using the JIS J000 screw bit.
  10. Samsung Chromebook Pro Hinge Replacement: passo 10, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 10, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 10, imagem 3 %32
    • Disconnect the black wire on the R1 plate connected to the screen using the precision tweezers.
  11. Samsung Chromebook Pro Hinge Replacement: passo 11, imagem 1 %32 Samsung Chromebook Pro Hinge Replacement: passo 11, imagem 2 %32 Samsung Chromebook Pro Hinge Replacement: passo 11, imagem 3 %32
    • Lift the hinge to remove from the Samsung Chromebook Pro.
Conclusão
5 outras pessoas executaram este guia.
Equipe
6 comentários
Great guide! One question: where can I buy the actual replacement hinge? Any tips?
Guy - Responder
I was able to find the hinges for mine on the Global Direct Parts web site. The item name is: OEM Samsung Chromebook Plus XE513C24, Pro XE510C24 Metal Hinge Set
Rob Riggle -
How did you remove/unloop the cables in the hinges? do they just come right off?
Darby -
The cables are just pushed into the side of the hinge. One side had a stopper holding the cable in place that I had to pull out, but the other had nothing holding the cable (that was the broken hinge on my chromebook, so maybe it had a stopper that had fallen out at one point). Once the stopper was removed from the one hinge, I could pull the cables out, and push them into new hinges.
Andrew Cullum - Responder
Just replaced these hinges on my computer … was only a bit confused with the stopper in the hinge but otherwise this guide was extremely helpful. Took about 30 min to do …
christophermdiaz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 38
Duração total: 8,384
