Introdução
This guide will explain the steps to replace your Samsung Chromebook 3 speakers. You will start by removing the bottom case.
O que você precisa
Place the Chromebook face down so the bottom case is uncovered.
Use the Phillips #00 screwdriver to remove all nine 4.6mm screws from the back case.
Quase terminado!
Conclusão
