Ir para o conteúdo principal
Samsung Chromebook 3 XE500C13-K05US LCD Replacement
O que você precisa
  1. Samsung Chromebook 3 XE500C13-K05US LCD Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop back cover facing up to show the screws.
    • Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
  2. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 2, imagem 1 %32
    • Use a nylon spudger or plastic opening tool to pop open the cover of the laptop.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 3, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 3, imagem 2 %32
    • Remove the cover showing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 4, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 4, imagem 2 %32
    • Unscrew and remove the four screws that secure the battery.
  5. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 5, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 5, imagem 2 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 5, imagem 3 %32
    • Use a spudger to pry underneath the battery cable connector, and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 6, imagem 1 %32
    • Lift the battery out of the case to remove it from the laptop.
  7. Samsung Chromebook 3 XE500C13-K05US LCD Replacement, LCD: passo 7, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement, LCD: passo 7, imagem 2 %32
    • Use a spudger to lift the hinge that locks the gold colored display cable in place.
    • Pop the cable out and remove the hinge from the motherboard.
  8. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 8, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 8, imagem 2 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 8, imagem 3 %32
    • Using the ifixit spudger, raise the adhesive holding the wireless card antenna wires.
    • Raise the black and white antenna wires with the ifixit spudger.
  9. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 9, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 9, imagem 2 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 9, imagem 3 %32
    • Remove the four 4.6mm screws from the display mounts.
  10. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 10, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 10, imagem 2 %32
    • Once the hinge screws have been detached, open the laptop.
    • The bottom of the laptop will divide from the screen once you are able to open it a certain amount.
  11. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 11, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 11, imagem 2 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 11, imagem 3 %32
    • Using the ifixit opening tool to pry in between the bezel and screen.
    • You will hear some snapping as you open the bezel with the ifixit opening tool.
  12. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 12, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 12, imagem 2 %32
  13. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 13, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 13, imagem 2 %32
    • Using the spudger, raise the adhesive tap that is holding the display cable.
  14. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 14, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 14, imagem 2 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 14, imagem 3 %32
    • Slowly raise the panel up and fold it over to uncover the display cable on the backside of the display.
  15. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 15, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 15, imagem 2 %32
    • Using the ifixit spudger, raise the hinge that is locking the gold colored display cable in place.
    • Pull the cable away from far from you to slide it out the monitor.
    • Be tender around the display circuit board, it is labeled "Do not touch."
  16. Samsung Chromebook 3 XE500C13-K05US LCD Replacement: passo 16, imagem 1 %32
    • Once the display cable has been detached, raise the screen up and out of the case.
Conclusão
Yamaris Acosta
Membro desde: 02/07/23
557 Reputação
Autoria de 3 guias
Equipe
Gateway, Team 4-4, Gonzalez Spring 2023 Membro de Gateway, Team 4-4, Gonzalez Spring 2023
GCC-GONZALEZ-S23S4G4
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 173
