Ir para o conteúdo principal
Samsung Chromebook 3 XE500C13-K05US Battery Replacement
O que você precisa
  1. Samsung Chromebook 3 XE500C13-K05US Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop back cover facing up to show the screws.
    • Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
  2. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 2, imagem 1 %32
    • Use a nylon spudger or plastic opening tool to pop open the cover of the laptop.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 3, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 3, imagem 2 %32
    • Remove the cover showing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 4, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 4, imagem 2 %32
    • Unscrew and remove the four screws that secure the battery.
  5. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 5, imagem 1 %32 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 5, imagem 2 %32 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 5, imagem 3 %32
    • Use a spudger to pry underneath the battery cable connector, and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: passo 6, imagem 1 %32
    • Lift the battery out of the case to remove it from the laptop.
Conclusão
Yamaris Acosta
Membro desde: 02/07/23
557 Reputação
Autoria de 3 guias
Equipe
Gateway, Team 4-4, Gonzalez Spring 2023 Membro de Gateway, Team 4-4, Gonzalez Spring 2023
GCC-GONZALEZ-S23S4G4
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 178
