Introdução
This guide explains the steps to replace your Samsung Chromebook 3 battery. You will start by turning your laptop upside down gently to remove the bottom case. Which is where your your battery is located.
O que você precisa
Place the laptop back cover facing up to show the screws.
Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
Quase terminado!
Conclusão
